Les Filtres Actifs Vintage / Vintage Active Crossovers
...et comptes-rendus divers
Re: Les Filtres Actifs Vintage / Vintage Active Crossovers
Messagede hornman » 28 Oct 2012 02:34
Marantz Model 3
Blocs mono à tubes
Messagede hornman » 28 Oct 2012 02:43
Marantz AD-5
2way multichannel electronic crossover network.
As for the cut-off frequency, the LPF and HPF side has been independent.
And it can select from 11 points (70Hz, 90Hz, 180Hz, 300Hz, 500Hz, 800Hz, 1.2kHz, 3.2kHz, 5kHz, 7kHz, and 10kHz).
A slope selector is a two-point slope selector which can choose two kinds of loss in quantity, 6 dB/oct and 12 dB/oct. And it is the knob with which the LPF and HPF side became independent.
A high precision conductive plastics volume with little error with a panel window is used for a level control. And the delicate sound volume of a right-and-left speaker can be adjusted with the Dual-unit type of a L-R independency.
By setting the switchpoint of a panel to INTERNAL, HPF and LPF can become a series connection, and it can operate as a band pass filter, and can upgrade to 3way and 4way by additional of AD-5.
The center channel for subWoofers is equipped. Cut-off frequencies are 70Hz, 100Hz, and 150Hz. The slope property is 24 dB/oct.
Informations en provenance du site Audio-Heritage
Messagede hornman » 28 Oct 2012 02:45
Marantz AD-6
The electronic crossover network used for a multi-amplifier system.
A basic stream composition consists of the high-pass filter (HPF) and low pass filter (LPF) which divide a stereo signal into a low-pass output and a high region output, and an 11-point selection is possible for it in a cut-off frequency to a HPF-LPF independency.
A switchover of 6 dB/oct and 12 dB/oct is possible for a slope property.
The super-low-pass center channel output only for three-dimensional system is carried.
Each output signal is from 0. - Level adjustment is possible to infinity.
Although it is a stream composition of 2way+three dimensional fundamentally,Development in multisystems in HPF and LPF being connected in series by the switchpoint change of the front panel, and functioning also as a band pass filter (BPF) and connecting AD-6 with two sets and three sets, such as three ways and a 4 way + subWoofer, is possible.
a circuitry is based on the stream composition which sandwiches the filter circuit according the buffer amplifier of a low-noise and a wide band to a resistor and a capacitor highly precise forward and backward in between -- low -- the distorted property is realized.
Messagede hornman » 28 Oct 2012 02:59
Mark Levinson LNC-2L
The electronic crossover developed aiming at the crossover which is not inferior to LNP-2 and JC-2.
LNC-2L consists of main-unit LNC-2L and power-source part PLS-153L.
Every one channel filter circuit of every of a high-pass and a lowpass consists of a total of four modules.
Adoption of this module construction has realized the cross over frequency specified as the user in a high robustness and precision.
Although LNC-2L is 2 way type, if two OCS modules of an option are incorporated, it is also possible to use it as a 3 way type by one set. However, the damping characteristics of a high region in this case serves as 6 dB/oct.
By LNC-2L carrying out a two-set (they being four sets when it is four ways) using, for forming 3 ways by 18 dB/oct, in that case, by using HX SERIAL INPUT, the high region can pass the filter for mid ranges, and can connect a preamplifier output to a high-pass filter direct.
Moreover, when using two sets and forming 3 ways, it is also possible to use one set at a time as 3 way type of a monophonic recording.
The MONO BASS functionality is carried.
Messagede hornman » 28 Oct 2012 03:04
Naim Naxo 3
Messagede hornman » 28 Oct 2012 03:06
Nakamichi EC-100 + PS-100
19 Fréquence réglable de 66 à 7400 hertz à 12 dB/oct + alimentation externe PS-100
Nakamichi EC-200
5 Fréquence réglable de 50 à 220 hertz à 12 dB/oct
Messagede hornman » 28 Oct 2012 03:10
Nikko CO-23
Nikko CO-23 elect crossover,
discrete, 2-way, 12-18 db/oct,
125-160-200-250-320-400-500-
630-800-1k-1250-1.6k-2k-2.5k-
3.2k-4k-5k-6.3k-8k-10k-12.5k,
Messagede hornman » 28 Oct 2012 03:11
Onkyo Integra D-655NII
Filtre actif 3 voies, 6 - 12 dB/octave.
Nombreuses possibilité de choix de fréquences de coupures et de recouvrements, ce qui en fait un deux voies capable d'être filtré de 90 à 8000 hertz, ainsi qu'en 3 voies.
la particularité de ce modèle, est d'avoir en plus un réglage d'amortissement ou de surtension à la fréquence de coupure en 12 dB/octave, 4 valeurs de Damping, de Q 0,7 à 1.
20 position par pas de 0,5 db sur les boutons de volumes.
Bass . Low Cut:
90, 125, 175, 250, 350, 500, 710, 1k
Medium . Low Cut:
Medium. High Cut:
710, 1k, 1.4k, 2k, 2.8k, 4k, 5.7k, 8k
High. Low Cut:
Slope property 6 dB/oct, 12dB / oct Dumping fator (12 dB/oct) 0. 7, 0.8, 0.9, 1.0 Level 0--20.5dB (43 points) Rated input 1V Insertion loss
Less than 0.8dB Input impedance 100kohm
Output load impedance 600ohms THD (1kHz, 1V) 0.005% or less S/N (IHF A network input shunt) 125dB or more Transient killer operating time At the time of SW-ON: About 7 seconds
At the time of SW-OFF: About 0.5 second The semiconductor used Transistor: 56 pieces
Diode: 47 pieces AC output Switched: Two lines
Unswitched: One line
They are a total of 1100 VA three lines.
Power consumption 18W
Dimensions:
L 440 - H 158 - P 360 mm
Poids 9.8 kg
Option Wood case CW-6
Messagede hornman » 28 Oct 2012 03:30
Pioneer SF-500 - 1971
en 3 ou 2 voies 12 dB/oct fréquences 600 5000 hertz
Messagede hornman » 28 Oct 2012 03:37
Pioneer SF-700 - 1972 - 1974
3 voied, 3 pentes de coupure 6-12-18 dB/oct, avec 5 fréquences de coupure
Pioneer SF-70
Idem SF-700
Messagede hornman » 28 Oct 2012 03:44
Pioneer SF-850 - 1974
3 pentes de coupure 6-12-18 dB/oct, avec 5 fréquences de coupure indépendantes en passe bas et passe haut
Messagede hornman » 28 Oct 2012 03:53
Pioneer D-70 - 1980
2 voies, 12 db/oct.
20 positions de coupures de 100 Hz à 8 kHz.
The electronic crossover network of 2 simple way designs which thought facility as important.
The high-pass filter part of buffer amplifier has adopted the positive/negative 2 power-source (±31V) pure complimentary Class-A SEPP circuit excellent in the high region property.
Eventh higher-harmonic distortion which occupies most distorted components is negated by a complementary circuit, and it is operating by the low distortion.
Moreover, it is the design which does not affect CR element of a filter by making an Output load impedance low for an input impedance highly.
The low pass filter part had a three-step stream composition, and the same positive/negative 2 power-source (±31V) pure complimentary Class-A SEPP circuit as a high-pass part is adopted as the first rank. Moreover, similarly the following stage has composition of pure complimentary Class-A SEPP according [ the first rank differential single emitter output circuit of positive/negative 2 power source and a final stage ] to a positive/negative 2 power-source first rank differential.
A loss and the leakage current use little element for the capacitor of a filter circuit, and the styrene capacitor of 2% of the error etc. is raising the riser of the frequency characteristic or sound, and the precision of the cross over frequency to it.
By the position of scaling-factor x1, even if a cut-off frequency takes 11 overlapping frequencies into consideration by the position of 11 places and scaling-factor x10, it can choose 21 sorts in the unit of an one-third octave.
The shutdown slope has adopted the filter in which it is 12 dB/oct and an attenuation has a linear slope property below in -80dB (it is 1/10,000 at a voltage).
Since cut-off-frequency changes are a lowpass / high-pass independency, they can also repeat the crossover of a Woofer and a tweeter.
For an exact level setups, the level control is using the attenuator type of 32 positions and a 1dB step.
The original level is correctly reproducible even if it moves the level set up once, since the memory marker sticks.
Moreover, if a network switchpoint is turned OFF, the signal from a preamplifier can output to a lowpass Variable termination as it is.
The rack-mounted adapter which can be carried in optional EIA specification rack, JA-R 2S, and JA-R 1S is attached (2U).
Moreover, if an adapter part is removed, a No. 20 series and breadth will become the same size.
The design which matched the separate amplifier No. 70 series of Pioneer is adopted.
Messagede hornman » 28 Oct 2012 03:58
Pioneer D23 - 1979
Un des filtre actif le plus réputé auprès des audiophiles, extrêmement complet avec 4 commutateurs de réglages de fréquences ayant chacun 11 positions. 4 positions dont 3 de pentes possibles, flat-6-12-18 dB/oct.
Le nombre très important de combinaisons lui permet une compatibilité avec la plus part des configurations d'enceintes, 2-3 ou 4 voies.
Messagede hornman » 28 Oct 2012 04:05
SAE 4000
Filtre avec multiplicateur de fréquence, permet de passer indépendamment le passe bas ou le passe haut de 100 à 10k hertz
Messagede hornman » 28 Oct 2012 04:08
Sansui CD 5
Messagede hornman » 28 Oct 2012 04:12
Sansui ECA-3
Utilisable en 2 ou 3 voies, fréquences de coupures 400, 600, 900 et, 4000, 5500 7500 Hz, à 6 ou 12dB/oct.
Particularité de ce modèle, il intègre 2 amplis de puissance stéréo qui peuvent alimenter aussi bien les graves, médiums et/ou aigus.
Messagede hornman » 28 Oct 2012 04:17
Sansui CD 10 - 1975
Filtre actif très complet, 2-3 ou 4 voies, pentes à 12 et 18 dB/oct.
Fréquences de coupures:
F1: 60, 75, 95, 120, 150 et 190, 240, 300, 380 et 480, 600 Hertz
F2: 300, 380, 480, 600, 750 et 950, 1.2k, 1.5k, 1.9k, 2.4k et 3k Hertz
F3: 1.5k, 1.9k, 2.4k, 3k, 3.8k et 4.8k, 6k, 7.5k, 9.5k, 12k et 15k Hertz
Messagede hornman » 28 Oct 2012 04:18
Sony TA-4300
3 voies, commutateurs sur le côté, 18db/octave basses - 12db/octave aigus - ajustable à 150, 250, 400, 600 hz & 3, 4, 5, 6.5 khz.
Messagede hornman » 28 Oct 2012 11:19
Sony TA-4300F
3 ou 2 voies, avec sortie grave sommée gauche droite pour utilisation d'un seul HP de grave.
18 dB/oct
bass: 150 / 250 / 400 / 600 / 800 / 1000 Hertz
treble: 1,5 / 2,5 / 3,5 / 4,5 / 6 / 8kHz
Bass boost: 0 / +3 / +6 / +12 en dessous de 150 Hertz
+18dB at 20Hz
Messagede hornman » 28 Oct 2012 11:24
Sony TA-4300F + TAD-43F
18 dB/oct
+18dB at 20Hz
4 voies avec le filtre grave complémentaire TAD 43F
Utilisateurs parcourant ce forum: Google [Bot] et 21 invités
