Valeurs de courants de NAD 312 ?
Messagede Anode » 02 Sep 2012 13:22
Bonjour quelqu'un aurait les valeurs de courants d'un NAD 312 ? car elles ne figurent pas sur les schémas.
Merci de votre aide.
Si quelqu'un les a ce serait cool et surtout les points de mesures.
Bien à vous
Anode
Anode
Re: Valeurs de courants de NAD 312 ?
Messagede smo35 » 05 Sep 2012 19:35
J'ai trouvé cela:
DO SO AT YOUR OWN RISK.
1. Idle current adjust (for L channel, same thing for R channel):
-Turn-off power, unplug power cord, disconnected speakers, turn volume control down to minimum,
-Series connect a 60W (voltage same of amplifier power supply) light bulb with the power cord(as over current protection),
-Connect a voltage meter across R455 (disconnected LK39 LINK),
-Turn R443 (220ohm) to maximum resistance,
-Turn-on power (do Not connect speakers),
-Turn R443 from maximum resistance and slowly down while watching the voltage across R455,
-Voltage across R455 should be between 0.02V to 0.05V
(The idle current = voltage across R455/1ohm which would be 20mA to 50mA, if you always playing loud music, set to 20mA, vice verse),
-wait 20-30 minutes make sure the temperature on the heatsink of Q415/417 would not get too warm (hot), if too warm, reduce current & vice verse).
2. Offset voltage adjust (for L channel, same thing for R channel):
-Connect a voltage meter across E401 and ground,
-Adjust R411 until get 0V on the meter
-It may affect the idle current, re-adjust R443 for the idle current if needed.
After adjustment, turn-off power and re-connect the LK39 LINK.
Turn-on power, make sure it's 0V between E401 and ground, connect speakers and play music, monitor the temperature on the output heatsink. Finally, disconnect the 60W light bulb, re-check above and minor adjustment may be needed.
Si l'anglais ne te gênes pas .....
smo35
Messagede dedefr » 28 Oct 2015 13:25
