Thank you very much. I will post more details with pictures about how I completely re-built the voice coil, and how I fixed the amp (My 680 was the last generation. The circuit was quite different from yours, and the schematic came with the speaker did not match the actual circuit. So I fixed the issue without schematic). Here is back of my unit. As you can see, the position selector is different from yours:
The back of the speaker
Literature comes with the speakers
Hi chaosrampant,
Thank you for the wonderful writing of the Master Control.
"You just have to also pay attention to the serious selector on the back of the enclosure: I put it to a minimum (position A or B) even pregnant raised on legs, otherwise it has a "physiological" absolutely unrealistic therefore too serious, tiring and it ruins everything, of course it is also seeking the boomer too ..."
This is very true. I found the bass performs the best when set the selector to position B no matter where you put the speaker.
Kind regards,
Tim
